Date/Time: Mon, 29 Apr 2024 08:24:43 +0000
In Replay: How to Show Vol (not just # of transactions) on Tick Chart?
View Count: 723
[2015-07-12 18:08:34] |
ged - Posts: 233 |
In Replay, what adjustments are necessary to make volume bars on a tick chart reflect actual volume, rather than the number of transactions per bar (which makes every volume bar identical)?
[2015-07-12 19:52:20] |
We are puzzled by this question. There is nothing special to do. Use the Volume study and this is all. Maybe you should provide an image of the chart. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-12 21:50:56] |
ged - Posts: 233 |
Here is a link to the image of the relevant chart window: http://www.sierrachart.com/image.php?l=1436737782636.png |
[2015-07-12 22:32:05] |
The reason the volume bars are the same is because the chart bars are set to be a fixed volume per bar of 1023.
