Date/Time: Sun, 28 Apr 2024 13:13:01 +0000
Unable to get peaks and valleys in volume profile
View Count: 1338
[2015-07-12 11:27:58] |
User75026 - Posts: 7 |
I couldn't draw the peaks and valleys in the volume profile. I have selected draw peak and valley, selected horizontal line for peaks and valleys, sensitivity is 10 and selected yes for include high low in peak and valley. What am I doing wrong. Please help.... http://www.sierrachart.com/image.php?l=1436700253484.png Thaks Joseph |
[2015-07-13 10:33:58] |
Thank you for posting on the support board. What is the "Extend Peaks and Valleys" input set to? It cannot be until Future Intersection. That will not work for the particular Volume Graph Period Type you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-13 10:53:58] |
Hi Extend peaks and valleys until end of period Joseph |
[2015-07-13 10:56:48] |
The only way we are going to be able to help with this, is to get the Chartbook. We cannot duplicate the problem and it is not obvious to us what is the problem. We need you to create a Chartbook that consists only of a single chart containing the Volume by Price study configured to show Peak and Valley lines and attach it here by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-14 00:09:18
[2015-07-13 23:57:58] |
Please find the attached chart book
Date Time Of Last Edit: 2015-07-14 00:08:41
Private File |
[2015-07-14 00:08:25] |
We do not see any Chartbook attached.
[2015-07-14 11:51:04] |
Hi Please find the chart book. Sorry beginer thanks Date Time Of Last Edit: 2015-07-14 22:19:28
Sierrasupport.cht - Attached On 2015-07-14 11:49:44 UTC - Size: 29.86 KB - 319 views |
[2015-07-15 03:05:49] |
In the Chartbook you have provided, the Peak and Valley lines are displaying properly: http://www.sierrachart.com/image.php?l=1436929508954.png We changed the colors. They are Yellow and Violet. Are you still not seeing them in this particular Chartbook? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-15 03:06:18
[2015-07-15 12:19:04] |
It'd strange, I could see it in the image you provided. But i cannot find it in my chart, I even changed the chart background to black.
[2015-07-15 12:46:41] |
I CHANGED PEAKS AND VALLEYS COLOR ALSO
[2015-07-15 18:55:01] |
OK we are thinking about this.
[2015-07-16 04:44:46] |
Re-download the data in the chart by selecting Edit >>Delete All Data and Download
[2015-07-16 11:07:28] |
If the above does not solve the problem we need to use remote assistance session to look into this.
[2015-07-16 11:17:59] |
Solved. I downloaded the sierra chart current version and it worked. Thank you guys
[2015-07-16 17:14:46] |
This is good. We did consider the version of the possibility but the version we saw you were running we thought was not a problem.
