Date/Time: Fri, 03 May 2024 21:52:39 +0000
fibonacci level
View Count: 778
[2015-07-12 07:32:27] |
User19479 - Posts: 25 |
why the fibonacci level is negative? I want 261.8% , but the price is below zero. Please check attached image |
a2acb0a0aeed6a1b3eb0ce206fcf3245.png / V - Attached On 2015-07-12 07:32:09 UTC - Size: 36.91 KB - 302 views |
[2015-07-12 19:48:35] |
When you manually do the calculation yourself, what result do you get?
