Date/Time: Mon, 29 Apr 2024 17:20:50 +0000
[User Discussion] - Klinger volume oscillator
View Count: 2899
[2015-07-11 22:40:13] |
Shane - Posts: 31 |
Does Sierra Chart have the equivalent of the Klinger Volume Oscillator? If not, can I get one of you code geniuses to convert the EasyLanguage for me? regards, shane EasyLanguage code follows: Type: Function Name: VForce Vars: TSum(0), Trend(0), DM(0), CM(0); TSum = High + Low + Close; IF TSum > TSum[1] Then Trend = 1 Else Trend = -1; IF Trend = Trend[1] Then CM = CM + Range Else CM = Range + Range[1]; IF CM <> 0 Then VForce = Volume * AbsValue(2 * (DM/CM) -1) * Trend * 100; Type: Function Name: KVO Inputs: FastX(Numeric), SlowX(Numeric); Vars: FXAvg(0), SXAvg(0); FXAvg = XAverage(VForce, FastX); SXAvg = XAverage(VForce, SlowX); KVO = FXAvg - SXAvg; Type: Indicator Name: Klinger Volume Osc Inputs: FastX(34), SlowX(55), TrigLen(13), Smooth(1); Vars: Trigger(0); Trigger = XAverage(KVO(FastX, SlowX), TrigLen); IF Smooth <= 1 Then Begin Plot1(KVO(FastX, SlowX), “KVO”); Plot2(Trigger, “KVO Trigger”); End Else Begin Plot1(Summation(KVO(FastX, SlowX), Smooth), “KVO”); Plot2(Summation(Trigger, Smooth), “KVO Trigger”); End; Plot3(0, “Zero”); |
[2015-07-13 04:08:12] |
bjohnson777 (Brett Johnson) - Posts: 284 |
Shane: Consider yourself lucky that I've been studying volume based indicators the past few weeks and found KVO interesting. On the flip side, this has been the most PITA project I've ever done... or at least close to it... Why? Everyone has the implementation wrong. Most web sites have the wrong formula and multiple versions of the wrong implementation. Even the few web sites that have the right formula have the wrong code several lines down. The code you posted is also wrong and probably won't run. The Scaling Factor is definitely wrong. There's nothing "easy" about EasyLanguage. It's nothing but a big mess that's hard to decode with missing pieces. It's also why I don't do mickey mouse class languages. I don't blame you for that, though. I'm just frustrated with all the previous problems. It's amazing how so many people have so much trouble with a simple 20 year old algorithm. :-/ Well, now Sierra Chart has THE ONLY PROPERLY WORKING VERSION ON THE PLANET! Fully Featured and Fully Documented! Histogram Included! Now I'm back to finishing the next indicator in my standard tool box. I've found some interesting things modifying it and will post it later this week. Offering To The Community: Klinger Volume Oscillator With Filters |
[2015-07-14 02:31:49] |
Shane - Posts: 31 |
Brett; Lucky indeed. Your comments are dead-on. When I looked at the logic described in the original article and compared it the posted EasyLanguage I noticed discrepancies. I started writing a spec for it anticipating that I was on my own. I very much appreciate your response and even more, your hard work creating the study. I will download it now and start putting it through its paces. regards, shane |
