Date/Time: Fri, 03 May 2024 01:48:07 +0000
stationary drawing tool
View Count: 845
[2015-07-11 18:30:01] |
User231363 - Posts: 31 |
Using ACSIL, I'm trying to draw a DRAWING_LINE to the right of the last chart bar, that stays in place when the chart is scrolled. I have tried using relative Tool.BeginValue & EndValue = 150, but that puts the line on top of the last bar, and the line scrolls with the chart data. Can you please suggest a way to do this? thanks! |
[2015-07-11 23:02:29] |
Please study the documentation more carefully first. This should really be obvious where you are going wrong. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html#BeginValue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
