Date/Time: Fri, 26 Apr 2024 17:25:34 +0000
SC v980 hanged on sc.GetTradeList
View Count: 1675
[2013-06-08 00:44:55] |
StarLight - Posts: 26 |
Hi Support, Could you verify on the example at http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html#scGetTradeList and output to message log? In a sim trade, scGetTradeList hanged SC. Cheers ... PS: Sorry about my last support request on SC v840 hanged on sc.GetTradeList. It is a typo mistake. |
[2013-06-10 09:44:17] |
Give a little bump ...
[2013-06-10 20:56:18] |
1. We now recognize what the problem is. It has to do with the differences in compiler implementations of the vector class. We are going to have to reimplement this function differently. It is going to require code changes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-10 20:56:53
[2013-06-11 06:07:44] |
Please update to the latest version and refer to the What's New page for more information about this.
