Date/Time: Sun, 19 May 2024 20:00:18 +0000
Gene Sheldon
View Count: 768
[2015-07-10 15:33:14] |
User72965 - Posts: 114 |
http://www.sierrachart.com/image.php?l=1436541878529.png I"m sending a chart >>>>>> My Q. is >>>> As you can see The open price on A profile is in Orange ...... Can I set chart to have the open in all letters?? Especially A through N ??????? Also I would like to have the Mid Range available for each letter profile ... Ex. > 2070 to 2065 Mid = 67.50 ~~ Either color it or have an marker there .. Either one .... I've gone into SG's .. Can't figure it out >> Also I get A opening notice of I need IB TWS 9392 or higher. I did download from Sierra charts as directed... Seems to have done ok ~~~~ But still get the notice >> Can you tell me what verison I'm using ??? And ? Do i this through Sierra or I. Brokers ???? Thx Gene :) |
[2015-07-11 01:36:30] |
Refer to the documentation here for these two TPO Profile Chart study Inputs that you need to set to Yes: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#HighlightOpenOfSubPeriodWithinProfile https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#HighlightSubPeriodMidpointBlock Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-11 01:37:35
