Date/Time: Tue, 28 May 2024 17:13:41 +0000
no connection status displayed after upgrade
View Count: 841
[2015-07-10 11:44:15] |
User60518 - Posts: 106 |
Hi - since upgrading I can no longer see the green (when connected), yellow (when connecting) or the red (when disconnected) - status bar in the file menu of my charts. Is it easy to add this back? CHeers |
[2015-07-10 17:59:54] |
This is not available on the prerelease at this time but will be next week. For now look at the title bar of Sierra Chart to see the connection status. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
