Date/Time: Thu, 02 May 2024 07:09:23 +0000
hide and show all studies - you guys get anywhere with that?
View Count: 926
[2015-07-10 05:33:58] |
4646ed - Posts: 230 |
I notice its been requested quite a few times over the last two years. Couldn't you just put an option to "hide all" next to the studies to graph window in the chart studies window. If you have a lot of studies in a lot of different open windows it would really save alot of time. Or even better, an option to hide all studies in all windows under the chart or analysis menus. |
[2015-07-13 20:50:23] |
Yes, we will see about this. We apologize for the delay with responding.
[2015-07-13 21:12:56] |
Hieronymus - Posts: 51 |
I'd love this as well. I have a macro that does it but its clunky.
[2016-02-24 07:50:33] |
User13668 - Posts: 291 |
I second this request. It would make it really easy to supply a 'clean' chart to SC when requested to do so by SC Support. I have 20 studies on some charts and it is time consuming to hide each one individually and then re-enable them individually. |
[2016-02-24 18:31:48] |
We will add commands to the Analysis menu for this. This way they can be easily accessed without going into the Chart Studies window and also keyboard shortcuts and Control Bar buttons can be added for them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
