Date/Time: Sun, 19 May 2024 14:46:35 +0000
Scaling number bars CL
View Count: 769
[2015-07-09 22:32:28] |
User808947 - Posts: 3 |
I'm using number bars for CL and can't see the numbers within each rectangle of a bar. I went to "scale" and can't find a way to make either less ticks per bar or make each rectangle taller (y axis) Thank you! |
[2015-07-10 03:09:48] |
First please have a look at the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#Scaling If you need more help, please post an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-10 03:10:09
