Date/Time: Thu, 03 Jul 2025 23:51:51 +0000
[User Discussion] - Change Origin For Bar Draw Style In Custom Study
View Count: 2067
[2013-06-07 23:41:16] |
BobD - Posts: 9 |
I have a custom study that plots a ratio. I would like to display it using the BARS draw style, however I would like the graph to be centered on 1.0 rather than 0.0 (i.e. so that values < 1.0 would plot below the horizontal axis). Is there a way to accomplish this?
[2013-06-07 23:42:43] |
You just set the sc.Subgraph [].Data values to what you require. This is all.
[2013-06-07 23:45:20] |
BobD - Posts: 9 |
When I do that the value (for example 0.5) is drawn above the axis at 0.0. What I would like is draw it down from 1.0 to 0.5. To the axis is centered on 1.0.
[2013-06-07 23:52:30] |
BobD - Posts: 9 |
The attach jpg shows what I have now. What I would like is to add 1 to labels on the Y axis, so that 0.0 become 1.0 and -0.2 becomes 0.8.
Date Time Of Last Edit: 2013-06-07 23:54:05
