Date/Time: Sun, 19 May 2024 14:30:17 +0000
Modify a Stop Order ASCIL
View Count: 1066
[2015-07-09 13:27:52] |
User96015 - Posts: 55 |
Hi, I' m building a trading system, and I need an information. When I enter to market, I put a Target Profit and a Stop Loss Order. The following bar I need to modify the Stop Loss order, and I don' t know how I can do it. Can u help me? Let me know, thx and bye. |
[2015-07-09 17:27:58] |
You need to use the sc.ModifyOrder function: http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#OrderModification Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-09 18:50:20] |
Ok thanks. Another question. I d like to know if Fib intraday data are avaiable and from wich data? I need to get Ftse Mib Future. Thx
[2015-07-09 23:17:58] |
Do you need real-time data for this market or just historical data?
[2015-07-10 07:35:10] |
Historical Intraday Data.
[2015-07-10 08:42:09] |
You will need to use CQG for the FTSE MIB on the Italian Derivatives market: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php We would also assume Interactive Brokers supports this market as well. In the case of CQG, you probably will need to wait about another 15 to 30 days until we have historical data support from CQG ready. Otherwise, there will not be any historical data when using Sierra Chart with CQG for this particular market. Update: However, we just thought that if you only require the cash market you can use the Sierra Chart Forex/CFD Data Service for this: http://www.sierrachart.com/index.php?page=doc/SCRealTimeFOREX.php The symbol is ITA40 when using Sierra Chart Forex/CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-10 08:44:30
[2015-07-10 09:27:11] |
Ok thx. Bye
