Date/Time: Sun, 19 May 2024 17:40:58 +0000
es
View Count: 672
[2015-07-09 12:41:07] |
User636508 - Posts: 6 |
yes i trade with apex but still should see the es symbol on here right?
[2015-07-09 17:13:12] |
Has Apex set you up with a live or demo futures trading account?
[2015-07-09 17:23:30] |
i am live with them
[2015-07-09 17:38:12] |
Can you ask them if they have set you up on the OEC trading service. If so, here are the set up instructions: http://www.sierrachart.com/index.php?page=doc/openecry.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
