Date/Time: Mon, 29 Apr 2024 01:51:54 +0000
Chart focus
View Count: 895
[2015-07-08 14:10:49] |
User224651 - Posts: 28 |
I have 4 charts in one chartbook. When I click from chart to another in the chartbook, the chart that I have just surfaced does not show the current bar on the right hand side of the chart. Instead, the chart has scrolled back in time. I then either scroll to the furthest most right bar to show the current price, or hit the 'End' button on my keyboard. Is there a setting in Sierra that will tell a chart to maintain the current bar when it it surfaced by clicking on the chart's tab in the bottom of a chartbook? Thanks. |
[2015-07-08 17:40:33] |
There is no option to support this. Make sure the charts are always scrolled to the end. Make sure Tools >> Synchronize Charts is unchecked. That option could be the source of the problem.
[2015-07-11 13:03:52] |
Thanks...this remediated the issue.
