Date/Time: Sat, 12 Jul 2025 00:56:49 +0000
[User Discussion] - Any Linux experts?
View Count: 1906
[2013-06-07 19:23:29] |
maxpi - Posts: 188 |
Under Windows OS SC can be configured in the Global Settings >General Settings to find it's dll's on a flash drive. When I'm running SC via Wine on Linux [Mint 15] the thumb drive doesn't show as a configuration choice. Is that doable somehow?
[2013-06-07 19:55:52] |
ganz - Posts: 1048 |
hi i'm not a Linux expert but i'm using SC on Linux yes, it's possible with ln command for exmpl if your data folder on flush-drive is /mnt/myFlushDrive/SC_Data then go to ~/.wine/drive_c/SierraChart/ ~:> cd ~/.wine/drive_c/SierraChart/ make sure you are not using any folder w the same name as the link will be using then make the link from this place to your flush-drive's data folder ~:> ln -sf /mnt/myFlushDrive/SC_Data myNewDataFolder make sure the link has been made ~:> ls -la start SC and choose myNewDataFolder gd lck Date Time Of Last Edit: 2013-06-07 19:56:10
[2013-06-07 20:02:06] |
tnx much
