Date/Time: Tue, 30 Apr 2024 02:42:10 +0000
Setting current chart as default for SetChartStudyValues
View Count: 770
[2015-07-06 18:45:57] |
DarthSidious - Posts: 63 |
sc.Input[].SetChartStudyValues() takes 2 parameters, the first being the chart number. In a study, I currently set it to 1 in the code, then change it as appropriate. I would like it to automatically set it to "current" chart number to which it is being applied. How can I do this? Thanks!
Date Time Of Last Edit: 2015-07-06 18:46:34
[2015-07-06 18:56:41] |
For the first parameter use sc.ChartNumber
