Date/Time: Mon, 29 Apr 2024 19:41:11 +0000
Missing historical data TPO,Volume by Price
View Count: 728
[2015-07-06 12:51:07] |
wat - Posts: 67 |
Hi, I am using Sierra Chart Real-Time and Historical Exchange Data Feed, but as you can see from attached screenshot, my data are broken from 5-26 and further in the history. Why is that? How can I fix it to have at least 180 days of precise tick data? |
missing historical data.png / V - Attached On 2015-07-06 12:45:02 UTC - Size: 70.83 KB - 280 views |
[2015-07-06 16:31:44] |
You need to use the Continuous Futures Contract chart feature: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
