Date/Time: Mon, 29 Apr 2024 17:40:00 +0000
Cumulative Delta - Up/Down Tick Volume Alert?
View Count: 1227
[2015-07-05 14:53:47] |
User237209 - Posts: 3 |
Hello, Is there a way to set up an alert if an up/downtick bar reaches a certain size and/or is consecutive. I searched the forum and can't find anyone setting up some kind of alert system for Cumulative Deltas, and the Subgraphs (Sg1 . . .Sg8) are non responsive. Are the Cumulative Deltas only for display and are not able to be manipulated? Your help and insights are always appreciated. Thanks |
[2015-07-05 20:46:29] |
We see no reason why this cannot be done. You would need to reference SG1 through SG4 in the Alert Condition Formula. These reference the Open, High, Low, and Last/Close bar values respectively. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
