Date/Time: Sat, 27 Apr 2024 13:19:03 +0000
Shorter time frame for the IB
View Count: 1729
[2013-06-07 16:24:15] |
Yes. This can be done by not using the Initial Balance Range related settings but using the Highlight Opening Range on TPO Profiles input setting instead. Documentation for this can be found here: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#TPOProfileSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
