Date/Time: Sun, 28 Apr 2024 18:49:14 +0000
Quote Board
View Count: 1635
[2015-07-03 18:16:40] |
User39772 - Posts: 311 |
I have a quote board with several symbols in it. When I mark the first symbol and press the arrow down key sometimes this causes a jump to the next symbol below the first symbol and so on ... but sometimes a press of the arrow key causes the slider on the right hand side of the board to move isntead of jumping from symbol to symbol. What is the reason for that behaviour ? |
[2015-07-03 18:27:01] |
First left click with your Pointer on a cell in the Quote Board before pressing the up/down arrow key. We are not able to duplicate what you are describing. It works exactly as expected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-03 18:38:04] |
mark a symbol with the left click of the mouse button, then click on the header of a coulum to enable sorting e.g. in alphabetical order. Then press up/dn arrow keys. |
[2015-07-03 18:39:36] |
after that mark the first symbol in the column again an press the up/dn arrow keys.
[2015-07-03 23:33:21] |
We will see how best to solve this. After testing this, we do see a problem where the selection box can display in the header area. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-04 14:15:46] |
Al SC Developer - Posts: 434 |
This should be addressed in the next version.
