Date/Time: Sun, 19 May 2024 16:25:49 +0000
Visualization Trend Charges
View Count: 1100
[2015-07-01 08:56:15] |
User22414 - Posts: 65 |
I had been an indicator (arrow up or arrow down) even developed for the visualization of trend changes in the Bund future on the basis of a Mov.AV-Hull and the "Spreadsheed system for trading". If the MovAv-Hull appears in column "T", then I have in the Sheed the formula: = AND (AT5> AT4; AT3> AT4) in K3 and M3 in the formula: = AND (AT5 <AT4; AT3 <AT4) entered. Suddenly, this indicator does not work anymore; apparently because of a software change. What I've found is because the "Spreadsheed system for trading" does not automatically acquires the data from the chart. Although attempts have as a test "Spreadsheed Study", this takes the data, processed but not my formula. Can you offer me a suitable solution, or detailed instructions (step by step) how I can program it yourself in the new software environment. |
[2015-07-01 10:34:53] |
Make sure the Chart Data Output Sheet Number Input with the Spreadsheet System for Trading study is set to 0 or to the Sheet number where you want to data outputted to. Here is the documentation for this input: http://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudyInputs.html#OutputSheetNumber Make sure also that your formulas are referencing the proper study columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-01 10:42:25
[2015-07-01 21:02:29] |
What I had expected, unfortunately again with a lot of copy just your standard answer, which is no help for my problem. I have described them exactly how I did it and how it has worked. I was hoping that they make a little effort and answer me step by step what do I do now another under the new conditions of the modified software to the same results occur. Thank you in advance !!!
[2015-07-02 00:35:36] |
We cannot provide any further information than we have without actually getting your Chartbook and Spreadsheet files. You can attach them here: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Otherwise, it is impossible for us to have a clear understanding of exactly the problem. Let us know what particular Chart Number is using the Spreadsheet study in the Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-02 00:36:32
[2015-07-02 16:35:13] |
Sierra Chart - Max - Posts: 5618 |
From user: To understand my problem I have attached them my chart and I will now explain in detail steps. Please speisung alimentation GBL-201509-DTB 36 trades with F6. As they look at position 7 Spreadsheeed system for Tading. ID:. 3 Previously, it was as if I had been awarded the Spreadsheed name in Settings and had secured appeared automatically at the bottom right what the labels (here TÄ) a new small window with the Exel-table, in which I was able to enter my formulas. (For example, the MovAv-Hull appears in column "T", then I have in the Sheed the formula: = AND (AT5> AT4; AT3> AT4) in K3 and in M3, the formula: = AND (AT5 <AT4; AT3 <AT4) entered).
Now this small window is therefore not created automatically with the Exel-table links. I try on the menu: FileOpen Spreadsheed. There I find under selection at the bottom: All Files in the second row from the top TÄ.StdyCollct. Now the small window on the right is indeed inserted down but the data do not run in the Sheed into it, so do not input my formulas possible. What am I doing wrong / how do you do it right now to change the software. Best Regards Helmut Sierra Chart Support |
[2015-07-03 11:47:56] |
Hey Max OK, you have my text from the e-mail used here, but that I could also do but I would not have my GBL-Chart can send them along. But what happens now? Have you read the text, and opened my chart and understand my problem? Can you help me now as the data in the Exel Sheed (TÄ) come or how I can generate a what is already linked automatically. Or at best you all do for me, like when you have modified my formulas, and I'll pay for the effort. Beautiful weekend, We have here 34°C,and Sunday there should be 38°. Helmut |
[2015-07-07 17:25:22] |
why I get no reports to my problem? Or has it been read none? Can it help not a qualified person from the sierra systems development? Has his origin in the "new Spreadsheed" that not go in through the chart data in my Exel scwbf-file. Yet have everything explained exactly when is it nevertheless more difficult to understand, then please contact me.
[2015-07-08 04:50:35] |
We are not really understanding this, and have not had much time to concentrate on it. We will get to it as soon as we can but we may not really be able to provide much help. In general, we recommend going through the instructions here to understand how the Spreadsheet study works and try yourself to determine where the problem is: http://www.sierrachart.com/index.php?page=doc/doc_StudiesSystemsAlerts.php#StepbystepInstructions This is always the best way because you have a better understanding of what you created and in combination with the documentation we have written you should be able to determine the problem. We also asked for the Spreadsheet file and did not receive that from you. You can privately attach it here following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-08 12:36:16] |
Thank you, why not earlier: yes with Spreashead System / Alert it works, it's not over Spreashead system for trading (as before)!!!!!!!!!!!!!!!
[2015-07-08 17:45:18] |
Please provide us the Spreadsheet file, so we can test this properly. This file has a SCWBF file extension. Privately attach it here following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-08 21:05:11] |
Now I do not understand what you want. It's obvious: spreadsheed "system for tarding" has an error. It is not automatically integrated to the chart at the naming, so the chart data do not come into it also.
[2015-07-11 00:38:25] |
We are checking this now. Thank you for your patience.
[2015-07-11 01:01:02] |
We have tested your Chartbook and a TÄ.scss spreadsheet file has been created and when doing a replay it updated with the chart data. We did not see any problems. We are suspecting based upon what we have read that you have been previously using the version of Sierra Chart with Old Spreadsheets and have updated to the version with New Spreadsheets. And when the Old Spreadsheet file has been attempted to be converted, it is failing. We cannot know for sure because we do not see exactly what is happening on your system. The easiest thing to do is to install the version of Sierra Chart with Old Spreadsheets. Here is the download link: https://www.sierrachart.com/downloads/SierraChartSetup.exe Let us know if that solves the problem. Refer to the attached screenshot of what we saw in the spreadsheet as it was updating during the replay. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-11 01:01:16
2015-07-11_130018.png / V - Attached On 2015-07-11 01:00:55 UTC - Size: 17.74 KB - 303 views |
