Date/Time: Sat, 18 May 2024 06:48:29 +0000
[User Discussion] - zig zag as a histogram
View Count: 1804
[2015-06-29 19:42:13] |
User97684 - Posts: 136 |
Hi, I was having a constant freeze of my charts, and it turned out to be my custom 'Zig-Zag as a histogram study'. So I can't use it any more. It is a mainstay graph for trading with VP, which sierra is so good for. Please would you be so kind as to modify your 'Zig-Zag Volume' if possible, to show the length of the swings, in points. Many thanks ves |
zig_zag_as_histogram_2.png / V - Attached On 2015-06-29 19:42:01 UTC - Size: 213.21 KB - 521 views |
[2015-06-29 20:19:56] |
You can already get this information from the standard Zig Zag study by setting the Display Length of Zig Zag Line Input to Points. It is unlikely we would add this capability to the Zig Zag Volume study. The zigzag study is already immensely complicated and we are not going to extend that complexity over to the Zig Zag Volume version of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-29 20:22:26
