Date/Time: Sat, 18 May 2024 04:37:20 +0000
[User Discussion] - Timeframe charts.
View Count: 732
[2015-06-29 19:04:46] |
Rhuz - Posts: 5 |
Hello I would like to see if it is possible to set the timeframe on a chart based on another chart. For example I want a 4 range ES chart and then I want a CL chart to be slave of the ES. With this I mean every time a new ES bar is created a new CL bar should be created too. So this way If we have 2 4 range ES bars, the first being 5:25 minutes and the second one 15 seconds we should have 2 CL bars lasting 5:25 minutes and 15 seconds. Thanks. Date Time Of Last Edit: 2015-06-29 19:07:19
[2015-06-29 20:15:59] |
This capability does not exist at all.
