Date/Time: Sat, 18 May 2024 04:04:45 +0000
Gann Fan w/ Volume Bars
View Count: 807
[2015-06-26 02:29:29] |
jakesans - Posts: 50 |
Hi SC- Just curious if calculation behind Gann Fan angles will dynamically calculate correct slope when using volume bars since time (x-axis) is variable not fixed? From what I can see it does not work with volume bars. It seems I am limited to fixed time bars for a correct angle. Please confirm. Thx, Jake |
[2015-06-26 02:49:16] |
There definitely is no consideration at all to Volume bars with this drawing tool.
