Date/Time: Sat, 04 May 2024 20:07:47 +0000
[User Discussion] - Renko Type Bar with different size reversal bar
View Count: 2437
[2015-06-25 20:15:26] |
User787778 - Posts: 139 |
Hi I want a Renko Bar that has a brick size of 3 ticks, but when the trend reverses, the reversal bar must be 5 ticks. Thank you inadvance. |
[2015-06-25 21:14:12] |
Sierra Chart does not offer this, but have a look at the Flex Renko Bar Period Type to see if you can get close to what you want: http://www.sierrachart.com/index.php?page=doc/doc_RenkoCharts.html#FlexRenko Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-25 21:31:23] |
Please consider it as an update.
[2015-06-26 22:45:58] |
Johnny - Posts: 99 |
Hello, that sounds interesting, I hope that you implement this feature.
[2015-08-24 19:32:17] |
Hi If have played around with Flex Renko as you suggested. I think that they would work if one could could have a "Reverse offset" that is greater than the "Box Size". Other software,like Unirenko, that is used by Ninja has this ability. Thanks |
[2015-09-10 19:36:55] |
Any comments Support?
[2015-09-11 05:42:22] |
Nothing from us. This has been marked as a User Discussion which means it is not something we will do any development/programming for.
