Date/Time: Sat, 18 May 2024 05:11:52 +0000
Data sharing
View Count: 749
[2015-06-25 08:01:51] |
wat - Posts: 67 |
Hi, if I bought 2 SC data feed connections, would I also need to buy exchange feed packages twice? Thank you. |
[2015-06-25 09:28:23] |
This is not clear for us. The Sierra Chart Exchange Data Feed supports up to three connections. You do need to pay for each of the connections. We are not sure what is meant by "exchange feed packages". This is not a term that we use. Being we do not know what this is, it is not something you have to pay for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-25 10:05:35] |
wat - Posts: 67 |
Hi, sorry, that was unfortunate expression. What I meant was that if I purchased Full CME Group (CME, CBOT, COMEX, NYMEX) for 3.25 USD/month, would that be just for one connection, or could I use it for both (In which case I would have paid $35 + $20 + $3,25 instead of $35 + $20 + $3,25*2). |
[2015-06-25 10:08:59] |
Each of the exchange fees applies to all three connections. So you just pay the exchange fee once.
