Date/Time: Sat, 18 May 2024 05:24:44 +0000
Moving Avg Simple Study Not Saving
View Count: 748
[2015-06-25 05:58:07] |
Trader Ra - Posts: 87 |
The moving average simple study is not being saved when trying to save as a study collection (single or otherwise). I can name and save it but when i try to load it from Analysis tab, nothing loads. This problem appears to have started after release of moving avg simple skip zeros study. I have ver. 1264 side note - Any progress on including a 'Save Selected' button to the studies window (allowing selection and saving of multiple studies but not all) ? |
[2015-06-25 09:37:25] |
Update Sierra Chart to the latest prerelease. This problem has been solved. Update with Help >> Download Prerelease.
