Date/Time: Sat, 18 May 2024 15:40:44 +0000
Server Connection Lost (TransAct) - the notification
View Count: 796
[2015-06-23 10:26:31] |
sampater - Posts: 243 |
The Server Connection Lost Alert not always work because i had many times when the Server Connection Lost not occur and the DF counter stoped for many minutes (TransAct Server).
SC: This cannot work with TransAct due to the fact that Sierra Chart does not maintain a direct connection to TransAct.
So, is there any way in the case of the TransAct to receive the notification that DF counter has stopped?? |
[2015-06-23 10:30:34] |
No there is not.
[2015-06-23 11:29:27] |
And, is there any read variable in ASCIL that return a value of the DF counter?
[2015-06-23 19:22:20] |
We will add this to the next release.
