Date/Time: Thu, 03 Jul 2025 04:20:09 +0000
Detect Chart Region
View Count: 939
[2015-06-23 06:29:14] |
CustomIndicators - Posts: 126 |
I just finished programming a new bot, but there is one thing that drives me insane. When I apply it to the chart with other subgraph indicators/bots, it doesn't draw some of the rays in the correct subgraph. Of course, this is because they are set to go into Region = 2; Is there a code I can use to automatically detect which region the bot landed in, so that it can just keep itself in line? I really want to switch that FreeDLL to 0. :) |
[2015-06-23 07:48:32] |
sc.GraphRegion
[2015-06-23 13:22:19] |
Thank you. Works like a charm. :)
