Date/Time: Wed, 28 Oct 2026 09:25:19 +0000
[Locked] - Chart scrolling
View Count: 2229
| [2015-06-18 16:54:20] |
| User699694 - Posts: 49 |
Hi I understand how holding teh Ctrl key and mouse on the proce action will move the chart Is there a way to reset the chart to: 1.The most recent price action 2. So that all analaysis techniques are included on the screen. At the moment I find myself having to repeatedly move the chart around to see what I want using the Ctrl function Thanks in advacne |
| [2015-06-18 17:00:45] |
1. Pressing the End key on the Keyboard will take you to the end of the chart showing most recent price. 2. So that all analaysis techniques are included on the screen. It is not clear what is meant by this.
Sierra Chart Support Date Time Of Last Edit: 2015-06-18 17:01:05
| [2015-06-18 17:58:05] |
Select Chart >> Reset Scales.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-18 18:18:56
| [2015-06-18 18:43:28] |
Here are the detailed instructions for resetting scales: Chart Scale and Scale Adjusting: Resetting the Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-08 16:32:58] |
hi with the hand tool you are able to move the chart horizontally, is there a similar function that will allow the chart to be moved vertically using the hand tool At the moment I am having to hold the ctrl key and then click on the vertical axis( price) to accomplish this and its tedious Thanks in advance |
| [2015-07-08 16:57:16] |
This is possible by enabling Vertical Scaling for the Hand tool. Refer to the documentation for this here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-15 14:09:28] |
Hi I have a tick.z chart open on a 1min time frame Of its own it keep on changing back and forth froma 1 min to a 2min? Any suggestions? Thnaks |
| [2015-10-15 17:27:26] |
Refer to this section here: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-15 20:38:54] |
Thanks Is there a quick way to center on the most recent price action Thanks |
| [2015-10-16 01:55:21] |
Refer to this page for the scaling options: Chart Scale and Scale Adjusting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-21 16:24:23] |
Hi is there a way I can have the high of the bar value plotted on the top of the bar and the low of the bar on the bottom of the bar? Thanks |
| [2015-10-21 18:15:44] |
Go to the Additional Files page: Additional Files (Study Collections, Spreadsheets, Chartbooks) There is a study collection named High and Low Bar Values which does what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-21 18:40:05] |
Regarding post #12, we did not upload the Additional Files page. This has now been done. So you would not have seen the file we mentioned. If you go back to that page and reload it in your web browser, you will now see the file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-22 21:50:56] |
I have multiple indicators on the chart and as such the price action is very scrunched How do I set it so that teh chart is centered on themost current price action and not scrunched Thanks in advance |
| [2015-10-22 23:15:27] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-11-20 23:11:39] |
Hi My sierra charts keeps on crashing, the whole computer reboots. Intermittently I get high CPU usage warnings by Sierra Suggstions? Thanks |
| [2015-11-21 02:32:59] |
This is generally an indication of a hardware problem on your system. A program like Sierra Chart which runs like a normal program using standard operating system functions, cannot cause a computer to restart. It is technically not possible. Check all of the hardware on your computer. Especially the memory and the hard drive or solid-state drive. To reduce CPU usage by Sierra Chart, refer to help topic 30: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Also Sierra Chart does not provide high CPU usage warnings. We are not sure what you are referring to. Also refer to help topic 17: http://www.sierrachart.com/index.php?page=doc/helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-08 14:39:00] |
Hi I am trying to add a symbol other than the options available of Triangle up, triangle down etc Is there a way new symbols or arrow types can be imported Also how does the custom text feature work? Thanks |
| [2015-12-08 17:20:32] |
Also whenever I use the text setting, there is a black background that surrounds the text, this sometimes obscures other indicators How do I get rid of the black background Thanks |
| [2015-12-08 17:29:46] |
Draw Styles that are not listed cannot be added. Custom Text is for special purposes for use by ACSIL to get certain settings: Advanced Custom Study Interface and Language (ACSIL) We are closing this thread. Start a new Support Request for any other questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-08 17:30:55
