Date/Time: Tue, 30 Apr 2024 16:18:14 +0000
[Locked] - Developing Value Area and POC
View Count: 5105
[2015-06-18 18:51:32] |
Yes. You need to use the Volume by Price study for this. Refer to the particular steps here for this: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#CalculatingDisplayingDevelopingPOCVALHLLines You need to set the Volume Graph Period Type to One Period of Fixed Bar Count. Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#InputVolumeGraphPeriodType Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-18 19:59:24] |
This is not supported: I want to retain those historical plotted values on the chart even if it is reloaded.
[2019-06-22 09:28:37] |
tommartin321 - Posts: 74 |
Refer to the particular steps here for this: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#CalculatingDisplayingDevelopingPOCVALHLLines You need to set the Volume Graph Period Type to One Period of Fixed Bar Count. Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#InputVolumeGraphPeriodType These two links produce an Error 404. Does anyone have the updated link? |
[2019-06-23 14:26:33] |
We apologize for that, we will get this resolved. For now, here are the direct links: You need to set the Volume Graph Period Type to One Period of Fixed Bar Count. Refer to the documentation here for this: Volume By Price Study: Volume Graph Period Type Refer to the particular steps here for this: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-23 14:27:30
[2020-08-02 17:37:50] |
User570584 - Posts: 1 |
I want to retain those historical plotted values on the chart even if it is reloaded. Hi, is this still the case where historical plotted values cannot be somehow saved and plotted when a chart is reloaded? Not sure why it clears the chart on reload. There is an indicator in NT8 that does this, essentially plotting value/VAH/VAL as a continuous line from data that looks back a set # periods. Code available in the 2nd to last post with link here: https://ninjatrader.com/support/forum/forum/ninjascript-file-sharing/ninjascript-file-sharing-discussion/4590-calculate-value-area-of-volume-at-price/page12?postcount=143 What advice do you have when attempting to import this C# code into SC? |
[2020-08-02 20:44:38] |
Hi, is this still the case where historical plotted values cannot be somehow saved and plotted when a chart is reloaded? What advice do you have when attempting to import this C# code into SC? This is definitively not supported at all.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-02 20:44:59
[2022-12-01 04:38:04] |
There's no One Period of Fixed Bar Count under the Volume Graph Period Type. Are you referring to One Period Based On Bar Count? |
[2022-12-01 12:29:12] |
Sierra_Chart Engineering - Posts: 14154 |
Yes. The name has changed. This is an old thread. We are locking this thread.
