Date/Time: Tue, 07 May 2024 23:30:38 +0000
PLEASE MAKE TOOL VALUES WINDOW SHOW LEVELS FOR PROJECTION AND EX
View Count: 1542
[2013-06-06 17:47:51] |
VF56381 - Posts: 2 |
I WANT TO SAY THAT I LOVE YOUR PROGRAM. COULD YOU PLEASE MAKE THE TOOL VALUES WINDOW SHOW THE LEVELS OF THE PROJECTION,EXPANSION,AND FIB EXTENSION TOOLS VALUES. I NEED TO SEE WHAT THE VALUES ARE IN ADVANCE IN ORDER TO HAVE ORDERS AT THESE LEVELS. WHEN THE PRICE APPROACHES THE LEVELS AND YOU DID NOT HAVE ORDERS WAITING IN THE QUE IT IS A SERIOUS PROBLEM. THANK YOU
[2013-06-06 20:49:20] |
M5amhan - Posts: 468 |
try looking at chart drawing properties > options > show price http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#DrawingToolConfigurationPriceRetracement not sure if its possible to see chart drawings in the tool value window |
[2013-06-06 23:06:40] |
Same advice as post #2. You just need to enable the option in the configuration for these drawing tools to display the Prices. You will also see the price of the levels as you draw the drawing.
