Date/Time: Sat, 18 May 2024 04:05:26 +0000
T&S
View Count: 1058
[2015-06-17 16:55:58] |
Crtfyd - Posts: 277 |
It seems that ALL the Time and Sales records are NOT saved. I had parameters of <=1 ask x bid saved as my T&S sales window. When I do a Replay of the morning I want to take off those parameters, then I save (because it didn't work before thinking this was the problem), BUT on the replay only the 1x1 bid/ask records show. I would think all the T&S records for the amount I set in Global Settings>DataTrade Services Settings>Number of Stored Time and Sales Records would be saved, not just what I have my current T&S's window to show. Is this a wrong assumption? It seems inadequate because how can one test different parameters? Thx |
[2015-06-17 16:59:48] |
When doing a replay the bid size and ask size will always both be 1. Also, the Number of Stored Time and Sales Records setting does not apply when doing a replay. The permanent storage of the trade data is not dependent upon this setting in any way. All trade data received from the data feed is stored. It is impossible for any of it to be missed unless the data feed did not send it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
