Date/Time: Sun, 19 May 2024 01:11:14 +0000
Using Sierra with Interactive Brokers data in free mode
View Count: 1107
[2015-06-17 06:27:15] |
User63460 - Posts: 1 |
Once my package for using Sierra chart expires can I continue to use Sierra Chart in free mode with a datafeed from Interactive Brokers? I read on your website that you would not provide support for the external datafeed but it was not clear whether it would continue to work or not. Thanks in advance for your response. |
[2015-06-17 16:32:22] |
You will require a paid account to connect Sierra Chart to Interactive Brokers. But you only need Sierra Chart service package 1 which is inexpensive: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
