Date/Time: Sat, 18 May 2024 12:27:34 +0000
Trades for Chartcalculator
View Count: 771
[2015-06-17 06:06:09] |
User825944 - Posts: 5 |
Hallo, I would like for Volumebased Charts Sum of trades. It is possible to add for the Chart calculator a label to do this? Thanks |
[2015-06-17 16:29:18] |
There is an option for "Volume" which adds together the volume across all of the bars that the Chart Calculator line spans across. It is not so easy for us to add another option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
