Date/Time: Sun, 28 Apr 2024 22:43:24 +0000
Round to nearest tick size
View Count: 1782
[2015-06-16 14:37:34] |
User106278 - Posts: 6 |
Hello. Is there a way to "Round to nearest tick size" for the Auto Retracement/Projection Study? If not, is it possible to add it? Thanks for the good work. |
[2015-06-17 12:38:25] |
User16114 - Posts: 153 |
There is a study "Round Study Subgraph to Tick Size" in the list of "Studies Available:" Right click in chart and then click "Studies" to see "Studies Available:" |
[2015-06-17 14:20:07] |
Thanks for this workaround. I have 10 levels on the "Auto Retracement/Projection" Study. This method would be to add the "Round Study Subgraph to Tick Size". Configure this study by having it based on "Auto Retracement/Projection". Then selecting the input data for a level (for example, period high). Add study 10 times for all other levels? Is this the way suggested or is there a way to add one study to modify all level? |
[2015-06-17 14:56:47] |
Sawtooth - Posts: 3980 |
You could use one instance of the Spreadsheet Study study, and formulas like the ones here: http://www.sawtoothtrade.com/example-3.html Otherwise, yes, you'd need 10 instances of the Round Study Subgraph To Tick Size study. Date Time Of Last Edit: 2015-08-14 02:23:14
[2015-07-05 00:30:11] |
We will add this capability: Is there a way to "Round to nearest tick size" for the Auto Retracement/Projection Study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
