Date/Time: Sat, 18 May 2024 10:42:30 +0000
ACSIL - sc.MaintainVolumeAtPriceData - related question
View Count: 859
[2015-06-16 03:09:19] |
ejtrader - Posts: 688 |
SC Team - If we have sc.MaintainVolumeAtPriceData = 1 in custom study - sc.UpdateStartIndex == 0 gets executed twice - this is understandable as it needs to populate VAP data. Question is - If we have this in multiple studies with - sc.MaintainVolumeAtPriceData = 1 on the same chart - does this statement sc.UpdateStartIndex == 0 - gets executed twice for each of the studies or only for the first study? It appears like - this executes for every study that is on the chart ( based on my tests ) and I think it is not necessary to perform this calculation for every study. Would you please check and comment? Thanks. Date Time Of Last Edit: 2015-06-16 03:11:34
[2015-06-16 09:46:03] |
Since the chart has to be reloaded to maintain the Volume at Price data, every study would would be called again with sc.UpdateStartIndex == 0. It is critical that every study is called because all of the study data arrays are cleared. Without this, studies would not display anything. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
