Date/Time: Sat, 18 May 2024 08:16:45 +0000
Volume By Price - Width
View Count: 1206
[2015-06-14 04:26:39] |
User93757 - Posts: 61 |
Hi, When making a volume by price composite the widths can by very large, if the dates go back and/or volume is large. The issue i'm having is that the start to end - volume profile is overlapping with the 30min or 15min bar/ and daily composites. I realize that you can adjust the "Maximum Volume Bar Width Percentage" in the study, but even at a percentage of 1, it is still to large. anyway to adjust it lower? It spills over in many cases if the volume/time frame is to large, thx |
[2015-06-16 04:20:46] |
What about setting the Maximum Volume Bar with Type input to Window. We would think that should accomplish what you need. We can allow a percentage less than 1 but see if that solves the problem first. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-16 04:58:00] |
Thx! I think setting "Maximum Volume Bar with Type input to Window" works!
Date Time Of Last Edit: 2015-06-16 05:06:31
