Date/Time: Wed, 18 May 2022 12:41:51 +0000
[User Discussion] - Spreadsheet Study to Existing Excel Workbook
View Count: 1100
[2013-06-06 05:04:24] |
AL324 - Posts: 7 |
Is there a way to link a spreadsheet study to a specified worksheet of an existing workbook? Ex. Sheet2 of ExampleWorkbook.xlsm |
[2013-06-13 04:03:24] |
Yes. Use the Spreadsheet Study and set the Chart Data Output Sheet Number input to the sheet number where you want to the data outputted to. Refer to this page for more information: https://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudyInputs.html Although this input may not work when using Use Excel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
