Date/Time: Fri, 18 Jul 2025 22:59:29 +0000
Sierra crash on multiple charts using Dynamic Memory Allocations Within Study Instance
View Count: 1019
[2015-06-08 20:56:56]
wwwingman - Posts: 185
Hi
I need persistence between study call so followed the instructions in the documentation on the Dynamic Memory Allocations Within Study Instance.
( http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DynamicMemoryAllocations ).
However, something seem to go wrong when I use the DLL on multiple charts. And it crashes SierraCharts.
Here is the simples sequence that systematically crashes my sierra :
1. Compile the a skeleton with the code below (The code comes from the documentation, I have not modified it).
2. Open Chart #1. Add the skeleton DLL.
3. Duplicate Chart #1 (=> Chart #2).
4. Close Chart #1.
5. Close Chart #2.
6. Sierra crashes.
Tested on 1259 and 1261 versions.
Please advise.
-- W.
The code of the skeleton :
#include "sierrachart.h"
SCDLLName("SierraSkeleton")
SCSFExport scsf_DynamicMemoryAllocationExample(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    sc.GraphName = "Dynamic Memory Allocation Example";
    sc.AutoLoop = 1;
    sc.FreeDLL = 0;
    return;
  double * p_DoubleArray = (double*)sc.GetPersistentPointer(1);
  if(sc.LastCallToFunction)
    if(p_DoubleArray != NULL)
      sc.FreeMemory( p_DoubleArray);
      sc.SetPersistentPointer(1, NULL);
    return;
  if(p_DoubleArray == NULL)
    p_DoubleArray = (double *) sc.AllocateMemory( 1024 * sizeof(double) );
      sc.SetPersistentPointer(1, p_DoubleArray);
    else
      return;
  p_DoubleArray[0] = 100;
  return;
Date Time Of Last Edit: 2015-06-08 20:57:38
[2015-06-09 01:52:35]
This problem will be solved in the next release. The persistent data had to be cleared when copying a chart.
