Date/Time: Sun, 05 May 2024 03:05:55 +0000
Missing Volume by Price on DOM (ZF)
View Count: 1158
[2015-06-08 06:29:17] |
EthanC - Posts: 44 |
Hi, The volume by price on DOM (Symbol: ZF), does not correspond with the chart. Kindly refer to attached. Thanks. |
Untitled.png / V - Attached On 2015-06-08 06:29:10 UTC - Size: 26 KB - 290 views Attachment Deleted. |
[2015-06-08 06:56:06] |
Select Chart >> Chart Settings and make sure the Session Times are set correctly. And for the Volume by Price study on the Trade DOM, what is the Volume Graph Period Type set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-08 07:18:36
[2015-06-08 06:58:15] |
Haha, you are right! I overlooked the session time. |
