Date/Time: Fri, 03 May 2024 09:50:26 +0000
Changing the color of candlesticks based on formula
View Count: 2190
[2015-06-06 15:56:24] |
User852270 - Posts: 1 |
http://www.sierrachart.com/image.php?l=1433605977900.png Is there a way for sierra chart to change the color of the OHLC bars based on criteria? for instance, make the OHLC bar Green if (Stoch > 50 AND RSI > 50 AND MACD fast line > slow line)? Also do the reverse for a red bar. |
[2015-06-07 00:27:11] |
You need to use the "Color Bar Based on Alert Condition" study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
