Date/Time: Wed, 11 Mar 2026 19:15:24 +0000
Auto scale range
View Count: 1139
| [2015-06-06 02:35:29] |
| FFTrader - Posts: 180 |
When I set the price scale range to automatic in all regions, the price / study will automatically be scaled to be visible. Can I have the labels of the studies / price to automatically be scaled to be visible too (for all regions please if possible)? Specifically the ZigZag Study's labels are not visible when the scale range is set to automatic. It would be ideal it is for all studies and all regions. Many thanks. |
| [2015-06-06 02:57:15] |
No. This is not supported. And it is not an area of development we would get involved with. It is complex.
| [2015-06-13 02:39:59] |
Should it becomes easier, please consider making it possible - it will make my life much easier without the need to manually scale it. Thanks anyway.
Date Time Of Last Edit: 2015-06-13 02:40:28
| [2015-06-13 03:59:22] |
| i960 - Posts: 360 |
Same thing happens with number bars scaling at times. You have to ride the y axis when moving around.
