Date/Time: Sat, 18 May 2024 05:24:47 +0000
Can't get Value Area values to appear in spreadsheet study
View Count: 731
[2015-06-05 15:26:36] |
User911705 - Posts: 89 |
Hello, I have added the volume at price study to a chart along with the spreadsheet for trading study. The point of control (ID1.SG2) shows up, but the value area values do not. On the study setup I see these items should be SG3 and SG4, they are set to draw, and I don't see any other settings to effect the correct behavior. The volume at price study is currently the only study (other than spreadsheet) I have in the chart. |
[2015-06-05 21:32:18] |
We have looked into this. The Volume Value Area High and Low are currently programmed not to be outputted to the Spreadsheet. If we change this, for users of Old Spreadsheets and those users who are directly referencing particular columns in formulas, and using the Volume by Price study, will have a problem with references. This is the reason why it has not changed. We may have to add an option for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
