Date/Time: Sat, 27 Apr 2024 21:47:45 +0000
Changing Font Size of Zig Zag study
View Count: 2073
[2015-06-05 10:58:02] |
User47066 - Posts: 3 |
I do not see an input for changing the font size for the Zig-Zag study. I tried changing the font on the chart via 'Chart > Graphic Settings > Fonts', but that did not affect the Zig Zag plotting. Any insight into how I can adjust the font for Zig-Zag? Thanks, Alex |
[2015-06-05 22:41:14] |
To change the text size for the Zig Zag labels, go to the Subgraphs tab of the Study Settings window. Select the Text Labels Subgraph. Change the Size setting. Set it to 0 to make the size automatic and the same as the Chart Text Font size. In the next version the font face for Zig Zag labels will be the same as the Chart Text Font. Currently it is set to "Arial". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-05 22:50:19
[2015-06-20 19:37:09] |
User77620 - Posts: 2 |
Please also make indicator "CountDown Timer"'s font the same as Chart Text Font. That ugly Arial number is killing me. Can't find anywhere to change it.
[2015-06-24 02:54:43] |
This is already the case. We do not think we changed it recently, but update to the latest prerelease to be sure.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-24 02:56:13
[2015-06-30 19:42:17] |
I just updated my SierraChart to the pre-release version and tried the CountDown Timer indicator. The font is not the same as Chart Text Font, and I don't think it's even Arial. It seems like my systems' default Chinese font... http://www.sierrachart.com/image.php?l=1435693079353.png |
[2018-11-25 19:09:58] |
nonojnet - Posts: 8 |
I've followed the instructions in post #2 but instead of the same font I'm currently using in all my global and chart graphic settings ("consolas" font for everything) Zig Zag still is showing the Arial font and when I set width/size to 0 becomes really big. Any help would be appreciated.
[2018-11-26 20:59:16] |
In regards to post #6, login to this Support Board with Help >> Support Board and post again when done. Your Sierra Chart account is expired.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-26 20:59:25
[2018-11-26 21:13:26] |
User7097040000 - Posts: 13 |
Re-post from my current account I've followed the instructions in post #2 but instead of the same font I'm currently using in all my global and chart graphic settings ("consolas" font for everything) Zig Zag still is showing the Arial font and when I set width/size to 0 becomes really big. Any help would be appreciated |
[2018-11-30 16:08:06] |
Support or anyone, any idea where is my mistake?
[2020-01-20 13:50:30] |
ycomp - Posts: 274 |
is there any way to change the actual font used for ZigZag labels?
[2020-01-24 02:07:09] |
Sierra_Chart Engineering - Posts: 14110 |
Refer to : Zig Zag: Text Labels Subgraph Description Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
