Date/Time: Sat, 18 May 2024 06:49:08 +0000
Gap in TradeDOM Depths
View Count: 873
[2015-06-05 07:55:48] |
AC95501 - Posts: 28 |
Dear SC-Support, for quite a long time now, I have a gap in the depths of FESX. Is there anything I could do to avoid this? Best regards Max |
Screenshot_1.png / V - Attached On 2015-06-05 07:55:45 UTC - Size: 8.36 KB - 392 views |
[2015-06-05 08:24:59] |
Does the gap go away if you select File >> Disconnect and File >> Connect to Data Feed? At least temporarily.
[2015-06-05 09:04:40] |
No. There's a gap for a few weeks already. I'm on TTNet.
[2015-06-05 17:01:52] |
Therefore you should contact your broker/trading service about this and let them know.
