Date/Time: Fri, 03 May 2024 15:33:09 +0000
Interactive Brokers daily sign off
View Count: 1909
[2013-03-26 21:24:28] |
User23815 - Posts: 209 |
I'm a new user. How does SC handle the required daily sign off of TWS by IB? Is it manual or can it be set to automatic? Also, does SC support using the Gateway? Thanks
[2013-03-26 21:34:58] |
When TWS exits for the day, Sierra Chart will lose the connection to it. Sierra Chart will continue to try to reconnect. You can use the TWS gateway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
