Date/Time: Sat, 18 May 2024 05:12:37 +0000
next chart
View Count: 1098
[2015-06-04 20:16:01] |
jonno - Posts: 13 |
Hi I just installed new sierrachart on new desktop. I seem to have lost the ability to move to next chart by using the plus/minus on the num pad. I have data downloaded for a few charts but nothing happens. Nothing happens when I use the f4 and f9 for next chart either. Any suggestions. Regards |
[2015-06-05 04:44:48] |
Refer to this section here for documentation for these menu commands: https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#AssociatedSymbolListMovingThroughSymbols Do you have Chart >> Only Symbols in Watchlist enabled? If so, disable this. Also make sure that keyboard shortcuts are set up for Window >> Next Chart and Window >> Previous Chart. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
