Date/Time: Sat, 17 Jan 2026 00:22:35 +0000
Issue with order management
View Count: 1373
[2015-06-03 17:45:06]
onnb - Posts: 664
2 issues we encountered today (version 1254) running in sim mode. Both of them very strange.
Have an automated trading system that places entry + OCO.
1. Had a trade open in sim mode. Trade had a working OCO limit/stop. Orders looked to be working fine in trade activity log and in the orders and positions window. Orders were not visible on the chart. Price had gone past the limit order and limit order did not get triggered. When I enabled "Show Orders and Positions" from the Trade menu, all of a sudden the limit order was immediately filled and stop was canceled. Did this same scenario twice just to confirm.
2. After this, "Show Orders and Positions" is selected and stays selected. I press on it and stays checked. Restarted SC and it still happens - can't uncheck it.
Any ideas what might be causing this?
[2015-06-03 17:58:52]
onnb - Posts: 664
Some more info on this.
Item 2 we were able to reproduce with the following:
1. Open a chart
2. go to the trade menu - enable/disable show order and positions works ok.
3. attach trade window to the chart - enable/disable stops working
4. detach trade window from the chart - enable/disable doesn't work
[2015-06-03 18:15:16]
1. This does make sense. Trade >> Show Orders and Position does need to be enabled for simulated orders to be filled. This is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_TradeSimulation.php#OrdersDoNotFill
We will make sure that when an order is submitted through an automated trading system that Trade >> Show Orders and Position is automatically enabled if it is not already.
2. This also makes sense if Trade >> Chart Trade Mode On is enabled.
Date Time Of Last Edit: 2015-06-03 18:18:53
