Date/Time: Wed, 02 Jul 2025 00:13:41 +0000
NQ chart has had issues for several days
View Count: 900
[2015-06-02 13:58:01] |
User106278 - Posts: 6 |
I use AMP Rithmic feed. NQ data is not showing the time accurately. Any ideas what the issue may be? I attached a chart and the chart setting. You can see it display quotes on what seems to be per tick. I have settings for a 10 minute chart. There are no studies on this graph. Thanks! Regards, |
![]() Attachment Deleted. ![]() |
[2015-06-02 14:58:28] |
There is a problem with the timestamps in the Intraday data file. Fully re-download the data by selecting Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-02 15:10:10] |
All good. Thanks!
